RYD779 for sale in New Zealand - $35,000 ($28,000 AUD / $20,000 USD / £14,900)
bought back to life over the last 3 years or so with rust behind the hinges and in the rear tubs, completely stripped down and all rust fixed with patch panels from a donor vehicle. Repair cert completed along the way. Car was originally red but had been painted green and matt black this was all removed before a fresh coat in factory AJ4 Red. under side was cleaned up and fresh under seal applied. Tank removed and cleaned out heat shields tank straps and subframe painted
New alien speed Carbon gear knob and ariel
New alien speed gas struts for boot
New pioneer head unit and 6 inch speakers
Lvvta certified and fresh re vin WOF and reg till 1/27
Engine drive line
Link g4x plug and play ecu
550cc injectors
Turbo Care TCRX400 dual ceramic ball bearing turbo 300kw capable with AN lines
VW coil over plug conversion
Custom 3” stainless exhaust
Custom 3” aluminium intake
Pod filter
Custom oil catch can with AN lines
New efi fuel hose through out
New fuel filter
Rebuilt started motor
New water pump
New radiator
New thermostat
New hoses
New coolant temp sensor
New oil temp sensor
New battery in boot
New Exedy heavy duty clutch
New clutch master cylinder
New slave cylinder
New intake and exhaust gaskets
Fresh redline oil in diffs and gearbox
Suspension and brakes
New Alien speed TDMI adjustable suspension
New LCAs
New polyurethane bushes through out
New Wilwood 4 pot front calipers 280mm drilled discs
New EBC yellow pads
Rebuilt rear calipers with New discs and pads
New custom braided hoses
Rebuilt master cylinder
Brembo fluid
Wheels
New Enkei rp01 17x7
New Tyres
Dyno tuned 265kw and 411nm at the wheels PM for dyno sheet
146xxxkms
Inner guards, brake ducts, sill caps (missing one) and rear mud flaps have not been installed yet and the uncut original front bumper has had a few repairs.
Missing tow eye cover
Paint needs a good polish and there's a couple of shallow dents which are hard to see
Spares
Rear diff subframe axles brakes and hubs
Front axles brakes and hubs
Drive shaft
Factory suspension x 2
Intake manifold
Seats
Wing
side skirts
Ac pump condenser and lines
35,000 ono
Engine drive line
550cc injectors
Pod filter
New fuel filter
New water pump
New radiator
New thermostat
New hoses
New oil temp sensor
New battery in boot
New slave cylinder
New LCAs
New EBC yellow pads
Brembo fluid
Wheels
New Enkei rp01 17x7
New Tyres
146xxxkms
Spares
Drive shaft
Intake manifold
Seats
Wing
side skirts
35,000 ono
