10/11/2026: 190RW9 for sale $35,000
FOR SALE: 1990 Nissan Pulsar GTI-R RNN14 – Built SR20, 440awhp, PAR gearset, Cusco RS rear and Moderna Engineering front diffs
Rego: Valid until July 2027
Price: $35000
Between a growing family, post-grad studies and full-time work, I simply don't have time anymore to enjoy this car. The car has been garaged for the past 10 years and is structurally rust-free.
Engine, Turbo and Fuel (E85):
PLR machined and balanced, 999 built.
Bored, torque-plate honed, decked, and line-honed block
Crack-tested and linished crank, honed conrod ends, and fully balanced rotating assembly
Ported cylinder head, machined valve insert recesses, and cut performance multi-valve seats
Ross Racing pistons and rings
Spool Drag I-beam connecting rods
ARP main studs and head studs
Permaseal MLSR head gasket
PLR billet timing chain tensioner
Supertech 1mm oversize valves and valve guides
Tomei Pro Cams (260-degree, 12mm lift)
Tomei rocker arm stoppers
Garrett GTX3076 turbo
FABLAB Custom Fabrication: Intake manifold, exhaust manifold (individual EGTs), forward-facing turbo setup, and a 3.5" exhaust with a megaflow resonator
Hypertune 77mm throttle body and intake piping
FPG high-output internal surge tank fuel system with Bosch 255 pickup and 460 delivery pump
Bosch 1250cc injectors (injectors maxed out on the dyno)
Turbosmart ProGate 50 wastegate and Pro Series BOV
Turbosmart FPR 1200 v2 fuel regulator
Accusump and Oil cooler with filter relocation
Drivetrain and Chassis:
PAR straight-cut 1st-4th gearset with helical 5th (rebuilt by Mr Transmission)
Moderna Engineering front torsen diff
Cusco RS 1.5 rear diff
Direct Clutch triple-plate clutch
Reconditioned rear subframe: dropped, powder-coated, fitted with new genuine bushes
BC gold coilovers
Cusco body bracing
Brakes and Wheels
5-stud hub upgrade
Wilwood 4-piston front brake upgrade
DBA T3000 slotted rotors front and rear
Enkei RPF1 wheels and Yokohama AD08R tyres
Electronics and Cooling
Link Fury ECU and Link AIM Dash
EKZ harness and wiring
PWR radiator with 4000CFM SPAL fan
PWR intercooler
GTR35 coilpacks and EFI cam trigger
LS1 alternator and battery relocated to the boot
3-in-1 catch can, coolant, and washer bottle
Exterior and Interior:
Crazy Hornet body kit (freshly sprayed)
Overall paint: Fair condition. It had a closed-door respray about 15 years ago, but the bonnet will need a refresh to match the new kit.
Interior: OEM in decent condition.
Notes:
Air-con is deleted.
Dash is badly cracked. Has a moulded mat on it.
Some odd jobs still exist, like plumbing the washer pump, calibrating fuel sender, replacing window motor and reattaching blue plate.
Probably plenty of stuff I've missed; it's been in build for years.
Flick me a message if you are genuinely interested or want to come take a look.
Price: $35000
BC gold coilovers
Cusco body bracing
Brakes and Wheels
5-stud hub upgrade
PWR intercooler
Notes:
Air-con is deleted.
