Welcome to the Nissan GTI-R Registry!
The complete VIN database and statistical production information for Nissan's Pulsar GTI-R and Sunny GTI-R models.
Nissan GTI-R Specifications
GO TO ADMIN PANEL > ADD-ONS AND INSTALL VERTIFORO SIDEBAR TO SEE FORUMS AND SIDEBAR
Administrator
Staff member
Joined
Messages
138
This data has been sourced from the Nissan Service Manual and official Nissan marketing materials.
  • Vehicle Identiifcation Number (VIN) Format: Pulsar: RNN14-****** | Sunny: JN1EGNN14U0-******
  • Chassis Type Code: Pulsar: E-RNN14 | Sunny: EGNN14
  • Length: 3975mm
  • Width: 1690mm
  • Height: 1410mm
  • Wheelbase: 2430mm
  • Tread (Track) Front: 1446mm
  • Tread (Track) Rear: 1421mm
  • Ground Clearance: 150mm
  • Kerb Weight: GTI-RA: 1220kg | GTI-RB: 1190kg
  • Fully Laden: GTI-RA: 1495kg | GTI-RB: 1465kg
  • Seating Capacity: 5
  • Turning Circle: 10.4m (5.2m radius)
  • Drag Coefficient: 0.39
  • Engine Model: SR20DET
  • Engine Code: 54C
  • Engine Type: 16 valve DOHC 4 cylinder with intercooled turbocharger
  • Displacement: 1998cc
  • Bore & Stroke: 86 x 86mm
  • Compression Ratio: 8.3:1
  • Throttle Body: Quad (one per cylinder)
  • Valve Lifters: Solid (shim adjusted)
  • Exhaust Valves: Sodium filled
  • Connecting Rod Bearings: 19mm wide
  • Control System: Electronic port injection
  • Fuel Injectors: 444cc, top feed, low impedance
  • Turbo: Garret TB2804 (T3/T25 combination)
  • Compressor: 60mm, 60trim .60A/R
  • Turbine: 53mm, 79trim .86A/R
  • Intercooler: Air-to-air 350x295x60mm
  • Turbo Pressure: 550mmHg (10.6psi / 0.73bar). Achieved using combination of brass restrictor and solenoid valve
  • Wastegate Spring Pressure: 360mmHg (7psi / 0.5bar). Used for "safe mode" (when detonation is detected)
  • Max Power: Pulsar: 169kw (227hp / 230ps) | Sunny: 162kw (217hp / 220ps) @6400rpm
  • Max Torque: Pulsar: 284Nm (29kgm / 209lb.ft ) | Sunny: 267Nm (27kgm / 197lb.ft) @4800rpm
  • Max Speed: 232kph (144mph) Note: The Pulsar was electronically restricted to 180kph (112mph)
  • Acceleration 0-100kph: 5-second bracket
  • Acceleration 0-400m: 13-second bracket
  • Steering: Rack & Pinion with gear-sensitive power assist and tilt adjustment
  • Suspension Front: Independent McPherson multi-link strut (hydro+telescopic), coil spring and torsion (sway) bar stabiliser
  • Suspension Rear: Independent strut, parallel link, coil spring and torsion (sway) bar stabiliser
  • 4WD System: "ATTESA" - Viscous Coupling, Centre Differential and Viscous LSD (open front, vlsd centre, vlsd rear)
  • Brake System: 4-sensor, 2-channel electronic ABS, 24mm master cylinder
  • Brakes Front: 257x26mm ventilated discs, 54mm single piston calipers
  • Brakes Rear: 258x9mm solid discs, 34mm single piston calipers
  • Wheels: 14 inch Aluminium 14x6JJ +40mm
  • Tires: 195/55R14 82V
  • Fuel Type: Premium Unleaded Petrol
  • Fuel Tank Capacity: 50 litres
  • Fuel Consumption:
    • 13.2ltrs/100kms (Urban Cycle)
    • 10.6ltr/100kms (Constant 120kph)
    • 8.1ltrs/100kms (Constant 90kph)
  • Boot Capacity: 280ltrs
  • Max Towing Weight: 1560kg
  • Transmission Type: 5-speed manual
  • Transmission Gear Ratios:
    • 1st - 3.285 (RA) | 3.067 (RB)
    • 2nd - 1.850 (RA) | 2.095 (RB)
    • 3rd - 1.272 (RA) | 1.653 (RB)
    • 4th - 0.954 (RA) | 1.272 (RB)
    • 5th - 0.740 (RA) | 0.911 (RB)
    • Reverse - 3.266 (RA) | 3.153 (RB)
    • Final Drive - 4.125
  • Paint Colour Codes:
    • KH3 - Super Black (Entire production)
    • AJ4 - Red (aka Active Red, Ultra Red - Series 1 only)
    • TJ1 - Grey Metallic (aka Bluish Grey Pearl, Blue Grey Graphite - Series 1, and the first half of Series 2)
    • KJ7 - Ivory White (aka Marble White - Series 1 only)
    • 531 - Super White (Series 2 only)
    • DL2 - Green Metallic (aka Greyish Green Metallic / Winter Green - Series 2 only)
  • Data Source Credit: www.gtir-registry.com
