LHD JN1EGNN14U0020513
Basic Info: Basic Info:
VIN: JN1EGNN14U0020513
Swedish Registration Number: STE268
Series: 1b Europe LHD
Color: Original KH3 Black
Year model: 1992-02
Power: 528WHP, 600+NM at 2,3 BAR (Dyno Sheets are available)
Gearbox: Quafie 5 speed
Engine Managemnent: Maxxecu Pro with Bluethoot connection to Samsung tablet. Shows everything in real time.
Extras: 2 extra gearboxes, 1 extra transfer case, OEM brakes, new syncros for Quafie box
Receipts: There are receipts for all the parts and labor that went into building this car. All parts were bought new and all receipts come with the car.
Condition:
-Very nice original interior with no tears
-Very nice original exterior with one small dent, some stone chips and some clearcoat missing on the rear wing. There is a crack in the windshield.
Engine specifications:
-CP pistons +0,50mm
-HD piston bolts
-Eagle rods
-Eagle crank
-ACL bearings (all bearings)
-Kelford cam shafts
-Supertech valves +1mm Inconel
-Kelford valve springs
-Cometic head gasket
-ARP head bolts
-AEM cam angle sensor disk
-Greddy by pass valve
-Apexi turbo timer
-Bosch EV14 injectors
-OEM manifold kit, water and pump
-Walbro 400lph fuel pump
-AEM fuel filter
-Fuel Lab fuel pressure regulator
-Nuke Performance fuel rail
-Turbosmart 45mm waste gate
-Turbosmart boost pressure regulator
-Japspeed manifold
-Borgwarner EFR turbo
-Maxxecu Pro Ecu with Samsung tablet and Bluethoot connection
-Larger front mounted intercooler, I cant find the receipt and brand name right now. Will update shortly
-Fan shroud with twin fans mouned on larger radiator, I cant find the receipt and brand name right now. Will update shortly
Drive line:
-Quafie gearbox
-Stracher Motorsports gearbox strengthening kit
-Clutch Masters clutch kit
-Clutch Masters fly wheel kit
-Yellow Racing coilovers
-Powerflex Black bushings for the complete chassis, engine mounts and gearbox mounts
-Compomotive 17x8 wheels
-K Sport big brake, kit 330mm 6 pison brakes
Included extras:
-2 OEM gearboxes
-1 OEM transfer case
- Complete set of brand new syncros for Quafie box
There is a lot of extras that I have not listed such as AN fittings, Silicon hoses etc etc but the above listed parts are the major ones.
Skicka vad du har att byta med så hör jag av mig om det är intressant. Kan även sälja bilen om någon vill köpa den. Priset kan så klart diskuteras ifrån utsatt pris :)
Finns massvis med bilder ifrån bygget etc.
Year model: 1992-02
Condition:
-CP pistons +0,50mm
-HD piston bolts
-Eagle rods
-Eagle crank
-Kelford cam shafts
-ARP head bolts
-Apexi turbo timer
-AEM fuel filter
-Japspeed manifold
Drive line:
-Quafie gearbox
Included extras:
-2 OEM gearboxes
